dsg transmission problem
Diskutiere dsg transmission problem im R32 Probleme/Fehler/Defekte Forum im Bereich Golf 4 R32; Hello I have Golf 4 R32 with DSG transmission vag-?om showed error Fault code 17085 - Transm. Control Module Range/Perfomance (SAE) or Control...
  • dsg transmission problem Beitrag #1
™B®embo™
Hello
vag-?om showed error Fault code 17085 - Transm. Control Module Range/Perfomance (SAE) or Control Module Defective (VAG) P0701 - 003 - Mechanical Failure Control Module
Part Number: 02E 300 046 E
Component and/or Version: GSG DSG 0507
Software Coding: 0000020
Work Shop Code: WSC 44551
and “PRNDS” light flashing
Two weeks before the incident, the car was in repair shop for oilservice in the gearbox. The repairman said that after the oil change it's nessesary to reflash the ECU. I think he downloaded the wrong firmware, because Golf 4 R32 DSG is a very rare car in Russia .
How can I check the correct firmware?
Thanks for any help
  • dsg transmission problem Beitrag #2
Hey :)
Dont get me wrong dude, but could you introduce yourself ? :great:
I've seen you're registered quiet a long time but never introduced yourself...
Anyway welcome...
In regards to your problem, it sounds like the Mechatronic has gone mad...
Dont think they flashed it, probably a reset.
  • dsg transmission problem Beitrag #4
phoenix84
phoenix84
That's not correct. However it should be reset to the default values/basic settings. Are you sure that the correct oil was used?
  • dsg transmission problem Beitrag #5
graeme86
™B®embo™, did you sort this issue? *noahnung*
Alexi
graeme86
orbitalRS
orbitalRS
