(english) Boost in FIS display?
Diskutiere (english) Boost in FIS display? im Elektronik (Allgemein) Forum im Bereich Elektronik; Smash, a guy on the tdi forum just recoded his CAN gateway like svenni suggested (i.e. reinput same code) and now his euro gamma radio with 3LB...
  • (english) Boost in FIS display? Beitrag #21
graeme86
Do you really think that recoding the CAN Gateway with the same coding will work?
Smash, a guy on the tdi forum just recoded his CAN gateway like svenni suggested (i.e. reinput same code) and now his euro gamma radio with 3LB wires to cluster now displays radio frequency in the dash, so this should work.
  • (english) Boost in FIS display? Beitrag #22
smash
  • (english) Boost in FIS display? Beitrag #23
Funny :D
I just suggested this to someone else having this problem, they tried it, and it worked! I hope it will work for me, too.
Well this procedure sounds funny but it is very easy to understood ;)
Everytime you recode the CAN gateway the gateway searches for CAN modules. If a module was found which is capable of driving the clusters display, the 3LB will be disabled. If none was found, the 3LB will be enabled.
  • (english) Boost in FIS display? Beitrag #24
smash
EMD-R 997
EMD-R 997
EMD-R 997
Schrottei
Jim_Knopf
akkarin92
flnstlw
Fix R32
Fix R32
Fix R32
