(english) Boost in FIS display?
Diskutiere (english) Boost in FIS display? im Elektronik (Allgemein) Forum im Bereich Elektronik; (english) FIS display? .........................
  • (english) Boost in FIS display? Beitrag #1
smash
  • (english) Boost in FIS display? Beitrag #2
graeme86
Hey Smash!
You get around! Welcome to the original and best R32 site.
The "3LB wires" are just the three connections required from the unit to the cluster so it can display in the cluster.
Your cluster should only have the big green and blue plugs on the back. (not the little red one in the middle as well - they are earlier)
The 3 wires go into the green plug as follows:
30-CLOCK
31-DATA
32-ENABLE
You will also have to add 16 to the cluster coding's first two digits with a VAGCOM, so it thinks it is connected to a radio/navi so it activates the display at the top to show your boost etc
That's the theory on how it all should work.
Regards
graeme86
  • (english) Boost in FIS display? Beitrag #3
smash
  • (english) Boost in FIS display? Beitrag #4
This unit works with the german clusters but i'm not sure if the US clusters have the 3 linebus, too. This bus is obsolete since 2001.
I'm working on a can based unit at this time:
https://www.r32-club.de/showthread.php?t=6151
  • (english) Boost in FIS display? Beitrag #5
smash
  • (english) Boost in FIS display? Beitrag #6
Does that require a computer inside the car? (Mini PC)
Yes, just like the Kufatec unit. But please keep in mind that this is no "normal" mini PC (car PC)! This is an embedded microcontroller system without any moving pieces like hard disks. The unit is fully compatible with the automotive temperature range (-40deg to +125deg).
What I'm wondering is if the 2003 clusters have the same pin-out or pins as the 2004 clusters. *noahnung*
Yes, it is the same. But that is not your problem ;) If your dealer has installed the new cluster correctly, he should have coded the unit for your country. This coding changes the language for messages and units (i.e. kilometer and miles). If i recode my german 1J0 920 846F unit to US, everything works except the naviation system display in the middle cluster display. I'm not sure why this is not working. Maybe this is because the US R32 have no OEM navigation system.
So this could be your problem :( But it works in all countries with a CAN bus adapter. This is one reason why i'm building my own system :) Another reason is that there is no need to install additional sensors for oil temperature or anything else except non original equipment like boost.
  • (english) Boost in FIS display? Beitrag #7
smash
  • (english) Boost in FIS display? Beitrag #8
Here in the USA, if we install an OEM NAV unit, we need a TMC box. *oops* Does that mean I won't be able to use the Kufatec module?
When you install the TMC Box you're using the infotainment CAN bus and NOT the 3 linebus (3LB). That was my suggestion, too :(
  • (english) Boost in FIS display? Beitrag #9
smash
  • (english) Boost in FIS display? Beitrag #11
smash
  • (english) Boost in FIS display? Beitrag #12
smash
  • (english) Boost in FIS display? Beitrag #13
graeme86
I'm pretty sure they left provision in the new clusters for the 3LB wires in case someone needed to replace their older cluster.
  • (english) Boost in FIS display? Beitrag #14
smash
  • (english) Boost in FIS display? Beitrag #15
smash
  • (english) Boost in FIS display? Beitrag #16
Try the following:
Use your diagnosis tool and connect to the CAN Gateway (Adr. 19).
Read the current module coding and rewrite this value without any change.
Also, make sure that the instrument cluster coding has the +16 at the first digits for the 3LB option.
But in fact, the 3LB software inside your dash could be removed by VW because this bus is obsolete since 2001. As far as i know, all US clusters use the CAN bus and DDP (display data protocol).
  • (english) Boost in FIS display? Beitrag #17
smash
  • (english) Boost in FIS display? Beitrag #18
I will try that first thing later. The cluster is coded as 23230, and I have also tried 23430 and 23130. It is the Great Britian / United Kingdom (UK) R32 instrument cluster, not a USA one. :D (The USA one was a Half-MFA)
Here is the coding:
de.openobd.org schrieb:
??xxx: add ons
+00 - no extra options
+01 - brake warning
+02 - belt warning
+04 - wiper water warning
+16 - Navigation/Radio
Coding 23230 means 16+4+2+1 = 23, so that is correct. Try recoding the can gateway ;) If anybody has connected a CAN device like the MFD with TMC box, the 3LB part will be disabled.
OK OK, UK cluster :D But keep in mind that a lot of clusters with same part numbers have different software versions on it.
Have you verified the cabling (EN,CLK,DATA) against the pinout of the green cluster connector ?
  • (english) Boost in FIS display? Beitrag #19
smash
  • (english) Boost in FIS display? Beitrag #20
smash
EMD-R 997
EMD-R 997
EMD-R 997
Schrottei
Jim_Knopf
akkarin92
Jochen92
flnstlw
