Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel
Diskutiere Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel im Motortuning Forum im Bereich Golf 4 R32; Finally, the dyno is working again. The Dyno: Mustang AWD Dyno, installed in October '04 The facts: Prior run, with CAI, and Catback the car...
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #1
r32brkwi
The facts:
Prior run, with CAI, and Catback the car dynoed at
201 HP max and 193 ft/lbs of Torque
same dyno, no fan but ambient Temp was 41 degrees (Dez '04)
Here the conditions, this time.
62 Degrees F
No Fan (sucks!) :x
Car was warm from prior driving
This Time, CAI, Catback Exhaust, GIAC Program 91 Octane
on 93 Octane Fuel
207 HP max and 200 ft/lbs of Torque, not what i expected
from GIAC :( but better then Stock.
Using the average Drive Train Loss of 29% (27-31% for AWD Vehicles)
the calculated Crank HP would be 291.55 HP :shock:
I'll get 100 Octane Fuel in a couple of days and then run again and compare :)
Here to the dyno-sheet
please go here for a larger image ->http://images.socalr32.com/album37/DynoRun3_29_05_post
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #2
Und jetzt bitte schön das ganze noch einmal in deutscher Sprache :) Dankeschön :wink:
Spaß beiseite: Kennt jemand den Umrechnungsfaktor von ft/lbs in Nm :?:
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #3
KuntaKinte
KuntaKinte
ft/lbs * 1,35 = Nm
Nm * 0,74 = ft/lbs
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #4
Aha, das heißt 100 ft/lbs = 135 Nm :idea: Alles klar :D
P. S.: Die Umrechnungsfaktoren für kW/PS sind fast die gleichen :roll:
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #5
KuntaKinte
KuntaKinte
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #6
Vielleicht gibt es da einen Zusammenhang *grübel*
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #7
vr-six
vr-six
Ja was hat er denn nu erzählt? Mir ist das leider zu kompliziert das zu entziffern.
Ist das interessant?
  • Dyno Sheet, CAI, Catback, GIAC 91Oct Program on 93 Oct Fuel Beitrag #8
r32brkwi
Uebersetzung fuer die nicht so internationalen R32 Fahrer
Nu denn Frau Hansen [Werner Stimme]
Das ganze auf Deutsch:
Endlich funktioniert der Leistungspruefstand wieder!
Der Pruefstand: Mustang Vierrad Leistungspruefstand, installiert im Oktober '04
Die Fakten:
Basislauf mit Kaltluft Einlass (Offener Luftfilter K&N Konus im vorderen Stossfaenger) Auspuffanlage ab Katalysator.
Der Wagen brachte 201 PS an den Raedern und 260,55 NM an Drehmoment, selber Pruefstand wie heute, kein Ventilator zur Kuehlung
Umgebungstemperatur +6.1 Grad Celsius
Die Bedingungen dieses mal.
17.7 Grad Celsius
Kein Ventilator :x
Das Auto war vorgewaermt durch die Anfahrt
Diesmal, Kaltluft Einlass, Auspuff + GIAC Chip mit 91 Oktan Programm aber 93 Oktan Benzin
207 PS an den Raedern und 270 NM Drehmoment, nicht ganz was ich durch den Chip erwartet habe aber besser als Serie.
Wenn man den Durchschnittlichen Kraft/Leistungsverlust von Allradfahrzeugen, 29% verwendet (27-31% bei Allradfahrzeugen)
dann wuerden dies theoretisch 291.55 PS an der Kurbelwelle ergeben :shock:
In den naechsten Tagen werde ich mir noch 100 Oktan Rennbenzin besoregn und auf das 100 Oktane Programm umschalten und einen Vergleichslauf machen :)
Hier der Ausdruck vom Pruefstand:
und hier findest Du ein groesseres Bild -> http://images.socalr32.com/album37/DynoRun3_29_05_post
Systi
Systi
LuiStyle
LuiStyle
Underground
zenetti
zenetti
zenetti
