COLD AIR INTAKE
Diskutiere COLD AIR INTAKE im Motortuning Forum im Bereich Golf 4 R32; hello, what you will choose? Pipercross K&N AEM Green Carbioni there is too much product, what is the best???
  • COLD AIR INTAKE Beitrag #1
hello,
Pipercross
K&N
AEM
Green
Carbioni
  • COLD AIR INTAKE Beitrag #2
Anonymous
Hi...
...the solution to realise a useful open airfilter (with cold air intake) is very difficult to find...we discussed this idea very often, but the best solution is a simple K&N filter, which replaces the serial filter in the R32 filtercase...when you think of buying an K&N 57i-Kit, be sure, that you isolate the hot air from the engine by the use of heat-shields made of aluminium...no tuner in germany uses open air filters...when the filter sucks this hot air, the engine´s performance gets down to 90%...that should not be the effect...
greetz
  • COLD AIR INTAKE Beitrag #3
defiant
@R32-schnurf
I have a simple K&N-filter in my filtercase. It makes a good work and I don't regret.
mfg
COLD AIR INTAKE
Alexi
Systi
Systi
