Dsp ?
Diskutiere Dsp ? im Allgemein Forum im Bereich Golf 4 R32; What's te difference between a dsp soundsystem from a R32 ( harmann becker amplifier ) and a soundsystem from a passat W8 ????
  • Dsp ? Beitrag #1
siebelink1
siebelink1
  • Dsp ? Beitrag #2
wob-i
thats a good question ... i think the w8 has more power ...
  • Dsp ? Beitrag #3
  • Dsp ? Beitrag #4
siebelink1
siebelink1
Dsp
And what is needed to build it ????
Can you use the original amplifier ?*noahnung*
  • Dsp ? Beitrag #5
No, the DSP amp is located in the baggage compartment. For this equipment you must add wiring harness from your MFD to the amp und recode the MFD.
  • Dsp ? Beitrag #6
siebelink1
siebelink1
dsp
Where can you get this wiring harness ????
M.f.g pascal
  • Dsp ? Beitrag #8
siebelink1
siebelink1
dsp
I'l have this wiring harness already but is there a difference between the golf wiring harness and the passat w8 ????
And can i us emy original amplifier or must it be replaced ?8-(
Greetings from holland :great:
  • Dsp ? Beitrag #9
No, there is no difference ;)
But you'll have to make sure that you buy the correct amplifier. Amplifier made for US cars doesn't work with your MFD/wiring harness ...
  • Dsp ? Beitrag #10
siebelink1
siebelink1
dsp
But the nokia amplifier isn't 8 x 80 watts !
I believe it's 4 x 50 .*roll*
Or i'm i mistaking ?
  • Dsp ? Beitrag #11
siebelink1
siebelink1
dsp
so when i'll buy the harmann becker amplifier everything schould work.
On 8x80 watts ?
Dsp ?
J_U_K_I
tiffy7777
tiffy7777
tiffy7777
UniniC1992
LB-R3207
  • Gesperrt
LB-R3207
LB-R3207
