DYNO DAY, EIPS STG2 and NA R32`s
Diskutiere DYNO DAY, EIPS STG2 and NA R32`s im Motortuning Forum im Bereich Golf 4 R32; Thought i share this with you guys .... we had a Dyno day last saturday and had 2 EIP stg 2 attending, one of the guys with the DBP stg2 has...
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #1
2u4uR32
Thought i share this with you guys .... we had a Dyno day last saturday and had 2 EIP stg 2 attending, one of the guys with the DBP stg2 has additional cams and forged pistons ...
2u4uR32 schrieb:
Thanks to Mario and Swift motorsports for being Great hosts... it was an interesting day and i know most people want to see the Turbo # but it was nice to see for us normal folks what our cars are worth, i really wished we had a bone stock car available to really compare to.
ATM`s R32 403HP.. 380 Torque
EIP stg2
http://s104.photobucket.com/al...4.flv
Marios beast he wasnt really happy with it today, watch how he says THATS IT and has 395HP with 450 Torque :eek: :laugh:
EIP stg2, cams, forged pistons...
http://s104.photobucket.com/al...8.flv
My sheet, GIAC, ABD intake, Supersprint catback...
This is a video from Ryan who did a Evom intake install inbetween pulls and the difference is quite impressive 18hp gains to the stock airbox.
REVO chip, Evom intake, stock exhaust
Anthony`s .:R with GIAC, K&N drop in Filter, EIP comp catback...
And maybe we should all just sell the .:R`s and get Evo`s :laugh:
Stock Evo with catback
Some pictures
Splisks schrieb:
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #2
zenetti
zenetti
Awesome~ !!!
EDIT: BLEW means what? ...mixture of "blue R that is blown by the eip stuff" ? ;)
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #3
lower4er
lower4er
Warum bricht denn die Drehmomentkurve immer so früh ein?
Und warum hat der .:R beim ersten Diagramm bei 403PS nur 380Nm? Da hab ich ja mit 300PS schon ca. 410-420Nm.
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #4
tanner1983
tanner1983
nice pics:great:
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #5
Kompressor-Robs
Kompressor-Robs
Das sind Lbft, nicht Nm, also ca. mit 1,35 multiplizieren
Robert
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #6
2u4uR32
Robert
This is correct... sorry forgot to mention this. Also please keep in mind that the Green R32 has a standard stg2 setup and was running full 17 pounds of boost.
The Blue R32 on the other hand ran short on power since his boost dropped down after 15 pounds he has some kind of issue, probably running to much torque for the software which closes the throttle body, i hope that the owner will chime in since he`s German :D
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #8
very nice!!:great: :great: :great:
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #9
Kompressor-Robs
Kompressor-Robs
I think, boost with 15 pounds should be enough also compared to 17,
but, this is quite much. Is this with lowered compression or stock?
Robert
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #10
Kompressor-Robs
Kompressor-Robs
Sorry, I think Stage 2 is already with lowered compression ratio with the forged pistons..
Only Stage B and 1 is stock, right?
Robert
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #11
2u4uR32
mariomllr schrieb:
well the green car is 10.3.1 compression ratio and the run was made at 17 psi of boost ...mine is 8.5.1 at 19psi peak but after 4800 rpm my ****ing boost went down to 15psi ,,that explains the power loss at hight end ...the car should be at over 500whp easly.....
And a EIP stg 2 doesnt come with forged psitons,
EIP Custom High Flow Fuel Injectors
EIP Low Compression stainless steel head gasket
EIP High Flow Fuel Pump
EIP Stage 2 Software Upgrade
Complete Head bolt set
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #12
lower4er
lower4er
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #13
2u4uR32
The Power is right where its supposed to be, BHP (power measure to the engine output shaft) he should have around +500hp, Keep in mind that the Dyno that EIP uses is a front wheel only dyno, this explains why their numbers are higher then on this 4wheel dyno. But having 400hp to all four wheels is still pretty insane :D
  • DYNO DAY, EIPS STG2 and NA R32`s Beitrag #14
Underground
nice numbers ! glad to see and hear that the EIP Turbos perform so well, can't wait to have our current project, the Series B on the dyno and if it's ready by then also the STG2 from Toddi. I'm curious if the numbers are different in Germany due to slight different ECU setup and fuel quality. We'll see and post here :)
keep up the good work,
Christian
UniniC1992
9 10 11
Alexi
Systi
Systi
graeme86
