Eine Messung bitte
Diskutiere Eine Messung bitte im Fahrwerk/Bremsanlage/Abgasanlage Forum im Bereich Golf 4 R32; Hallo Leute. :) Gruß aus Australien!!! Bitte helfen Ich bin richtig Euro Fahrwerk Nachrüstung auf meinen Australischen R32 (wir haben...
  • Eine Messung bitte Beitrag #1
graeme86
Hallo Leute. :)
Bitte helfen
Ich bin richtig Euro Fahrwerk Nachrüstung auf meinen Australischen R32 (wir haben US-Suspension)
Ich brauche die Messung von Mitte Hinterradnabe bis Unterkante des hinteren Kotflügel
Bitte mit vollem Tank.
Ich brauche Messung zum Einrichten der Höhe hinten richtig.
Vielen Dank
Graeme
  • Eine Messung bitte Beitrag #2
Hi Graeme,
What do you want to adjust if you install the original EU Spec suspension?
Fix height, nothing to adjust !
Tom
  • Eine Messung bitte Beitrag #3
graeme86
Hi Tom
You need to set the height of the hub without the springs/wheels installed to tighten the control arm bushes correctly without tension, so I am looking for a standard measurement.
  • Eine Messung bitte Beitrag #4
ok I see... Dont have that measures though...
Still common sense should perfectly do it !
Do not believe that your dealer will do that upon measuring... ! ;)
  • Eine Messung bitte Beitrag #5
graeme86
Like you say, maybe they can be tigtened back on the ground or up on a ramp, but very difficult to get to outer bolts this way..
The workshop manual describes the procedure as measuring the height beforehand and tightening without the wheels on etc, but we of course do not have this distance with our higher suspension.
  • Eine Messung bitte Beitrag #6
37cm should be ok !
  • Eine Messung bitte Beitrag #7
graeme86
I have 37cm written down here from when I took off my US suspension (which is considerably higher than the Euro).
2 cm lower was quoted in original sales brochure, but I don't know if US suspension was raised as well from standard 4-motion.
  • Eine Messung bitte Beitrag #8
what I have is 39 for a normal mk4 so +/- -2cm for the R lets me assume it should be around 37... hmmm maybe the documentation is wrong.
if I look at pictures of US spec R's they do not seem higher than EU spec...
Original measures US SPEC
Height 56.1 in 1,424 mm​
Ground Clearance 4.2 in 107 mm
source : http://www.r32argent.ca/R32%20information_files/r32%20tech%20specs.pdf
  • Eine Messung bitte Beitrag #9
graeme86
As you can see ours are visibly higher than Euro!
I have a UK sales brochure that says "20mm lower than standard Golf" , but I also have an Austrian sales brochure (Prospekt) that says "drei Zentimeter tiefere Sportfahrwerk"!
Hence my confusion.
  • Eine Messung bitte Beitrag #10
Nice *lol*
Looks like a Golf .:R32 Country *lol*:D
  • Eine Messung bitte Beitrag #11
graeme86
Danke :D :D
Eine Messung bitte
Gast11191
